Supermetrics and Power My Analytics both collect, prepare, store, and analyze marketing data. Power My Analytics suits teams that want an included managed warehouse and broad connector access. Supermetrics is better suited to teams that need a larger connector and destination ecosystem, more architectural choice, or AI workflows spanning dashboards, early-access campaign management, and custom data products.
The right fit depends on your sources, account volumes, destinations, and required plan features.
Disclosure: This comparison was produced by Supermetrics using publicly available product pages and documentation reviewed in September 2026. Features, pricing, currencies, and plan limits change and may vary by billing region. Before buying, verify the exact sources, fields, destinations, refresh frequencies, and account limits required for your use case.
  • Power My Analytics includes managed warehousing and Data Builder with its paid plans.
  • Supermetrics publishes the broader connector and destination catalog and offers more choice over where data lives.
  • Both support APIs, MCP, and AI-assisted analysis. Supermetrics also offers Studio, developer products, and early-access campaign management.
  • Verdict: Choose Power My Analytics when its included warehouse and plan capacity match your workload. Choose Supermetrics for more complex data stacks, enterprise governance, or broader AI and product-building workflows.
Supermetrics vs. Power My Analytics at a glance
Power My Analytics bundles managed warehousing and broad source access, while Supermetrics provides greater breadth and architectural choice.
Category Supermetrics Power My Analytics What it means for buyers
Core model A marketing intelligence platform spanning data integration, optional storage, reporting, AI, early-access campaign management, and developer products A marketing data hub built around connectors, included managed warehousing, reporting destinations, Data Builder, AI Insights, API access, and MCP Both products now cover much more than data connectors
Connector catalog A broader public catalog that includes standard, Premium, and Early Access sources Advertises access to 80+ data sources The required connectors, fields, and plan entitlements matter more than the headline count
Managed storage Optional storage alongside temporary connector storage and delivery to customer-owned destinations Managed warehousing included with paid plans Power My Analytics makes warehousing the default; Supermetrics provides more architectural choice
Data preparation Custom metrics and dimensions, currency conversion, blending, and data import; availability varies by plan Data Builder supports multi-source preparation, filtering, blending, and custom calculated fields Both products support data preparation; compare the exact operations and plan entitlements you need
Reporting and data destinations Spreadsheets, BI tools, Supermetrics Studio, AI tools, APIs, warehouses, lakes, and file storage Spreadsheets, BI tools, APIs, warehouses, databases, file storage, and MCP; some exports require an add-on or Custom plan Check which specific reporting and data destinations you need before committing to either vendor
AI workflows Direct AI integrations and MCP, AI-built live dashboards in Studio, and early-access campaign-management workflows MCP access plus AI Insights for dataset analysis and recommendations Both support AI-assisted analysis; their publicly documented workflows diverge beyond analysis
Best fitTeams with broader or more complex data stacks, governed enterprise requirements, AI campaign workflows, or custom data-product needs Teams that value included managed warehousing and whose sources, destinations, and account volumes fit Power My Analytics's plans The strongest choice depends on your specific requirements
What do Supermetrics and Power My Analytics do?
Both Supermetrics and Power My Analytics collect marketing and sales data, but they package storage, reporting, governance, and downstream uses differently.
Power My Analytics centers its product on a managed warehouse, with Data Builder, reporting destinations, AI Insights, API access, and MCP. Supermetrics supports direct reporting, Supermetrics Studio, AI tools, customer-owned warehouses and lakes, optional storage, transformations, campaign management, and developer products.
The main differences concern breadth, packaging, governance, and what teams can do with their data.
1. Data sources and connector coverage
Supermetrics publishes the broader catalog, while Power My Analytics advertises access to 80+ sources within each plan’s usage limits.
Total connector coverage
Supermetrics publishes the broader catalog, while Power My Analytics advertises access to 80+ connectors. Check the live Supermetrics directory and Power My Analytics directory for the sources you use or expect to add.
Does the connector expose the fields you need?
A connector name alone doesn’t show whether it supports the data and behavior your reports require. Compare fields, attribution settings, history, refresh frequency, and backfill behavior using representative accounts.
Source limits and account limits
Supermetrics Starter, Growth, and Pro include three, seven, and ten sources respectively, with the same number of accounts allowed per source. Power My Analytics Business includes five sources and five total accounts. Grow and Pro include unlimited sources, with seven and twenty accounts per source respectively.
An agency managing five Meta Ads and five Google Ads accounts would exceed both Power My Analytics Business and Supermetrics Starter but fit within either company’s next plan. Compare the complete capacity and cost, not only the catalog size.
2. Destinations and reporting
Both platforms support mainstream reporting tools and data platforms. Supermetrics publishes a broader named destination catalog, while Power My Analytics charges extra for some exports.
Spreadsheets and BI tools
Both Supermetrics and Power My Analytics support Looker Studio, Google Sheets, Excel, and Power BI. Supermetrics Starter, Growth, and Pro each include one core destination, with extras available. Power My Analytics includes Sheets and Excel from Grow, but not Business.
Warehouses, databases, and file storage
Supermetrics publishes the broader named catalog, while several Power My Analytics exports require an add-on or Custom plan. Supermetrics supports BigQuery, Snowflake, Amazon Redshift, Azure Synapse, Databricks, Microsoft Fabric, Amazon S3, and Google Cloud Storage. Warehouse destinations require Enterprise.
Power My Analytics supports BigQuery, Snowflake, Amazon S3, FTP, Azure SQL, MySQL, and PostgreSQL. BigQuery, SQL, and FTP exports are add-ons below Custom.
Native dashboard experience
Supermetrics offers a native dashboard environment, while Power My Analytics primarily prepares data for external reporting tools.
Supermetrics Studio turns AI-generated reports into live dashboards that users can edit through natural-language instructions and share with permission controls. Power My Analytics, on the other hand, can prepare data in Data Builder and send it to external reporting tools, subject to plan and add-on availability. It also provides templates.
Supermetrics suits teams that want a native reporting environment while Power My Analytics suits teams that already have a preferred visualization tool.
3. Data storage and warehousing
Power My Analytics includes managed warehousing with paid plans, while Supermetrics offers temporary connector storage, optional Supermetrics Storage, or delivery elsewhere.
How Power My Analytics stores data
Power My Analytics makes managed warehousing the default across its paid plans.
It stores aggregated, report-ready data in an encrypted Google Cloud datastore. Custom customers can use their own warehouse and select sovereign storage options.
How Supermetrics stores data
Supermetrics lets customers choose between temporary storage, optional Supermetrics Storage, and customer-owned destinations.
Storage Basic is a Pro add-on, while Enterprise includes broader storage, warehousing, and regional controls.
Which storage model is better?
Power My Analytics prioritizes simplicity while Supermetrics provides more control over the long-term architecture.
Neither model is inherently safer. Both companies report SOC 2 Type II and ISO 27001 certification, so compare retention, residency, deletion, and permissions.
4. Data transformation and preparation
Both platforms can prepare and combine data. Power My Analytics includes Data Builder with every paid plan, while Supermetrics reserves full Data Transformations access for Enterprise.
Power My Analytics Data Builder
Data Builder provides no-code preparation, blending, and calculated fields on every paid Power My Analytics plan.
Data Builder supports field selection, date controls, filters, multi-source blends, and calculated metrics or dimensions built with formulas or conditional rules. Power My Analytics labels Create Field as beta. Destination availability varies by plan and add-on.Every paid plan includes Data Builder. The free Sample Data plan also includes it, but only for sample data.
Supermetrics Data Transformations
Supermetrics provides broader documented transformation controls, but reserves the full toolset for Enterprise.
Its visual editor supports blending, business rules, naming conventions, currency conversion, and custom metrics or dimensions. Growth and Pro include one Custom Data Import configuration.
Which platform is stronger for data preparation?
Power My Analytics offers more accessible packaging but Supermetrics supports more extensive documented standardization and governance. Test both with your production logic before buying.
5. AI analysis, MCP, and campaign actions
Both platforms connect marketing data to AI. Supermetrics supports a wider set of ready-made AI workflows and extends them into early-access campaign management, while Power My Analytics focuses on data access and analysis.
Power My Analytics’s AI Insights identifies trends, anomalies, and period-over-period changes in Data Builder and produces recommendations. Its MCP server connects the Power My Analytics Hub to Claude, ChatGPT, and other compatible clients. Published plans include MCP access with OAuth authentication.
Supermetrics offers direct integrations for ChatGPT, Claude, Microsoft Copilot, and Gemini Enterprise, plus a Supermetrics MCP server. For MCP access, each user authenticates through OAuth 2.0 and sees only their authorized accounts.
Supermetrics also publicly documents an early-access campaign-management capability for selected advertising platforms. After explicitly granting write access, users can create or update campaigns from a supported AI tool. New campaigns are created paused, approval requirements can be configured, and actions are recorded in Campaign History.
6. APIs and custom products
Both companies provide API access, but Supermetrics presents the clearer proposition for building branded, multi-customer products on top of its data infrastructure.
The Power My Analytics API returns JSON for custom applications, BI tools, and warehouses and supports historical exports. Paid plans include API access; Auth Links start on Grow.Supermetrics offers a Data API and a Platform API for workspaces, permissions, regions, keys, and usage. Build on Supermetrics adds branded authentication, connection management, and white-label delivery. It presents the stronger documented proposition for multi-customer products.
7. Security, governance, and support
Both Supermetrics and Power My Analytics report SOC 2 Type II and ISO 27001 certification and encrypt data in transit and at rest.
Power My Analytics deletes client data on request or when service ends. Custom adds sovereign warehouse options, SLAs, and custom contracts. Supermetrics Enterprise offers region selection, SAML SSO, multiple teams, and custom user and account limits. For MCP, it documents individual OAuth authentication, session isolation, and no use of customer data to train public models.
Power My Analytics also offers email support on Business and Grow, priority support on Pro, and a dedicated representative on Custom. Meanwhile, Supermetrics Enterprise includes premium support and a Customer Success Manager. Compare contractual SLAs and the security controls relevant to your environment before selecting which vendor to choose.
Which platform should you choose?
Choose according to your complete workflow: sources, account volumes, preparation needs, destinations, governance, and planned AI use.
Choose Power My Analytics if you want managed warehousing included and your sources, destinations, and account volumes fit its plans. It offers accessible data preparation without an enterprise contract.
Choose Supermetrics if you need broader connector or destination coverage, more control over where data lives, or enterprise transformation and governance. It is also the stronger fit if you want native AI-built dashboards, early-access campaign actions from AI tools, or infrastructure for a branded data product.
Before deciding, run the same proof of concept in both platforms. Connect representative accounts and test:
  • The exact metrics, dimensions, and historical range you need
  • Refresh times and report performance
  • One realistic blend or transformation
  • Your required destination and user permissions
  • The final price, including add-ons and account growth
Supermetrics vs. Power My Analytics: the verdict
Power My Analytics is a good option when its included warehouse and plan packaging fit your workload, while Supermetrics is stronger for breadth, governance, and more advanced downstream uses.
Power My Analytics has developed into a capable marketing data platform. Its included warehouse, Data Builder, API, MCP server, and mid-tier packaging make it a credible choice for teams whose requirements fit its ecosystem.
However, Supermetrics offers the broader route from data collection to reporting, AI-assisted analysis, early-access campaign action, and custom product development. It’s the better fit for teams with more varied data stacks or more demanding architecture and governance needs.The right decision starts with your workload. List the sources, fields, accounts, destinations, and controls you need, then test both platforms against that list.
If Supermetrics fits your requirements, start a free trial or request a demo to test it with your own marketing data.
