Yes, AI agents can support campaign management with controlled access and human review. Start with read-only analysis, then introduce changes on selected accounts with approval required for every live edit. Supermetrics, a marketing intelligence platform, connects campaign data and supported actions to your AI tool and provides the controls to manage that access.
- AI agents can investigate campaign performance and propose changes with read-only access, so you can test them without giving permission to edit your ad accounts.
- Read-only workflows still carry risks, including incorrect analysis and inappropriate data disclosure. Write access adds the risk of those mistakes affecting live campaigns.
- Supermetrics lets you choose which ad accounts an agent can edit and which live changes, from budget edits to enabling a campaign, need human approval.
- Supermetrics creates new campaigns paused, and Campaign History records each change so you can undo supported actions.
- Verdict: Test the agent’s reasoning before granting write access, and require approval for live changes. These controls reduce risk but they don’t guarantee correct decisions.
What can AI agents for campaign management actually do?
Supermetrics gives your AI tool access to connected campaign data and supported campaign actions. The AI uses those tools to investigate performance, recommend a response and carry out changes within the permissions you grant. You can move from analysis to action in the same conversation.
Ask an agent to "Investigate why cost per acquisition (CPA) rose," for example. The agent can choose which data to check and follow the evidence. That investigation needs only read access, but editing a campaign requires separate write permission.
Supermetrics makes that connection through its Model Context Protocol (MCP) server. Depending on the ad platform and permissions you grant, your workflow can:
- Retrieve performance data across accounts, channels and date ranges
- Create new campaigns and ad groups with budgets and targeting
- Draft ad copy and creative variations informed by your campaign data.
- Update supported budgets, bids and campaign settings
- Pause ads, ad groups or whole campaigns
You can connect Supermetrics to your favorite AI tool using Supermetrics for Claude, Supermetrics for ChatGPT, or Supermetrics for Gemini Enterprise. Supported ad platforms include Google Ads and Meta Ads, with available actions varying by platform and AI integration. Check the campaign management documentation for each platform's available actions.
What does a controlled campaign workflow look like?
Suppose Meta CPA rose last week. Having connected Supermetrics to Claude or ChatGPT, you can then move from investigation to a reviewed response:
- Investigate: Identify the campaigns driving the increase, allowing for conversion lag.
- Check the evidence: Compare relevant breakdowns to investigate the cause.
- Propose a response: Show the affected account and campaign, with before-and-after settings.
- Review and act: With "All live changes" selected, approve the live adjustment before it applies.
- Follow up: Check Campaign History and compare results.
You spend less time investigating and switching platforms, while keeping control of the live change.
What are the real risks of letting an AI agent manage campaigns?
The six main risks are overspend or mistargeting, optimizing the wrong goal, bad data, data exposure, prompt injection and off-brand ad copy. McKinsey reports that 80% of organizations have encountered risky behaviors from AI agents, so these risks aren’t just hypothetical. Write access raises the stakes because a mistaken recommendation could become a live change. Read-only workflows still need checks for accuracy and inappropriate data disclosure.
Can an AI agent overspend or launch the wrong campaign?
Yes. A budget or targeting mistake can turn a useful recommendation into an expensive error. Before a campaign goes live, check for accidental errors, like:
- A daily budget set at $5,000 instead of $500
- Location targeting set to the US when the brief said Canada
Supermetrics creates new campaigns paused, so you can catch these errors before enabling them. Review changes to existing live campaigns just as carefully.
What if an agent optimizes the wrong goal?
An AI agent can meet your stated target while undermining the business outcome. This problem is known as specification gaming.
For example, an agent asked to lower cost per click (CPC) could recommend cheaper, low-quality traffic. CPC improves, but fewer visitors become customers and your pipeline shrinks.
Give the agent the business goal behind the metric, including conversion-quality requirements and targets for CPA or return on ad spend (ROAS). The agent can then assess cheaper clicks against the outcome you need.
What if the AI agent works from bad data?
Even a well-defined goal can lead to the wrong recommendation if the data is incomplete or misunderstood. Before acting, check for:
- Misread or invented metrics
- Mismatched attribution windows or conversion definitions
- Platforms claiming credit for the same conversion
- Stale or incomplete data
For example, TikTok CPA may appear to double while conversions are still arriving. Before cutting spend, ask the agent to check reporting completeness and conversion lag.
Supermetrics retrieves connected marketing data without repeated CSV uploads, making source data easier to use. You still need to account for different attribution windows or conversion definitions.
Set reporting rules for attribution and conversion definitions before comparing channels, then check that the agent follows them. Our guide to reducing AI hallucinations in marketing explains how to ground the analysis.
Marketing agency Layer tested and validated Claude’s output before using it with clients. Using Claude and Supermetrics reduced certain custom reporting tasks from up to 10 hours to 20 minutes, giving the team more time for strategy. Check out the complete Layer case study to read their full story.
How do you keep client data separate when using AI agents?
If a shared connection gives an agent access to several clients’ accounts, it could pull the wrong client’s figures into an answer or report. Restrict each client workspace to the accounts it should see, even when the agent has read-only access.
Supermetrics’ Client Account Isolation, currently in beta, lets you choose which accounts are visible in each client workspace. These visibility restrictions are separate from permission to edit campaigns.
What is prompt injection, and why does it matter for campaign agents?
Prompt injection happens when an agent encounters malicious instructions in material it reads, such as a landing page, and follows them instead of your brief. Those instructions could try to redirect its actions or make it disclose data.
Limit the accounts and tools the agent can access, and require approval before it changes live campaigns. These controls can reduce the potential impact, but campaign approvals alone don’t prevent prompt injection or data exposure.
Can an AI agent write off-brand or non-compliant ad copy?
Yes. When drafting ad copy, an agent can drift from your brand voice or add unsupported claims, such as "guaranteed results."
Give it approved messaging to work from, then review the draft against your brand guidelines and the platform's requirements before publishing.
Which campaign tasks are safe to hand off to AI agents today?
The safest starting point is analysis and proposals. Once you can verify those outputs, move to paused campaign creation or reviewed changes on a selected account.
The table compares each task's risk and recommended control. "Low" tasks don’t change a live account, but still need accuracy and data-use checks. Our roundup of the best AI agents for marketing covers which tools handle each task.
| Task | Risk level | Recommended control |
| Performance reports and summaries | Low | Check key figures and review before sharing |
| Anomaly spotting (CPA spikes, delivery drops) | Low | Verify the anomaly and investigate possible causes before acting |
| Ad copy variations | Low | Run brand and compliance review before upload |
| Drafting new campaigns | Medium | Create paused but review settings before enabling |
| Suggesting budget shifts | Medium | Review the evidence and before-and-after budgets |
| Autonomous budget changes | High | Require approval initially; assess narrowly scoped exceptions |
| Launching live campaigns | High | Review setup and require approval before enabling |
The amount at stake matters too. A $2,000-a-month test account offers a lower-risk place to test the agent’s reasoning. Larger accounts need closer scrutiny of the potential spend impact. In either case, the reviewer needs to know about context the data can’t show, such as next week’s product launch.
How does Supermetrics help you stay in control?
Supermetrics provides account-level write permissions and approval settings, so you can decide where an agent may act and which changes need review. Campaign History lets your team inspect what changed and undo supported actions.
Set up account access and approvals in Supermetrics Hub using the campaign management setup guide.
Which approval setting should you choose?
Start with "All live changes": it requires approval for changes to live campaigns, including enabling one.
As you gain confidence in a workflow, you can choose a narrower approval requirement. "Going live" covers enabling a campaign; "Budget + going live" also covers live budget changes. "No human approval" applies changes immediately, so reserve it for low-spend tasks the agent has handled reliably.
Alongside the approval setting, define which proposals need the account lead’s sign-off. For example: “Any proposal that takes a campaign’s daily budget above $1,000 requires the account lead’s approval.” An increase from $800 to $1,400 would trigger that rule.
This is a team review policy, not an automatic dollar threshold configured in Supermetrics.
To make each review useful, ask the agent to show the exact proposed changes and the evidence behind them. Before approving, check:
- Every budget figure, before and after
- Targeting, including locations and audiences
- Start and end dates
- The exact account and campaign each change touches
Use a new campaign's paused state to complete these checks before enabling it.
How should you scope an AI agent's permissions and access?
Separate permission to read data from permission to edit campaigns, following the least-privilege principle: each user or system gets only the access its job requires. In Supermetrics Hub, enable write access only for selected accounts. Your ad-platform permissions also determine what the agent can do.
For analysis, leave write access disabled. Scope data visibility separately, especially for client work, and remove access when it is no longer needed.
For changes to spend, set caps inside each ad platform, such as the Meta Ads account spending limit, and check who can modify them. A platform cap will hold even if the agent misreads an instruction. If larger changes need a second reviewer, include that step in your team's process alongside Supermetrics' approval settings.
What security and compliance checks should you run?
Permissions control what an agent can access, while security policies govern how that data is handled. Review both Supermetrics and your AI provider's hosting, access controls and data training policies.
Supermetrics undergoes SOC 2 Type II audits, is ISO 27001 certified, and supports SSO and regional hosting. It doesn’t use customer data to train public models. For more information on these controls, check out the Supermetrics security page and Trust Center, and make sure to read up on your AI provider’s policies too.
How do you monitor and reverse campaign changes?
After a change goes live, compare results with the intended outcome. Watch spend pacing, CPA and delivery, allowing for conversion lag. Check overall account performance too, because improving one campaign may reduce conversions elsewhere. Conversions falling to zero after a change can point to broken tracking.
If results warrant a reversal, open Campaign History in Supermetrics Hub to inspect the change and undo supported actions. You can also request a supported reversal through your AI tool.
Agree on rollback triggers before making changes, so your team knows when to intervene. Reversing a setting can’t recover spent budget or guarantee a return to earlier performance.
How should your team get started with AI agents safely?
Start with one account and a real performance question. Check the agent's reasoning before giving it permission to make changes:
- Connect Supermetrics to Claude or ChatGPT and one low-spend ad account, such as a $2,000-a-month test account, leaving campaign write access disabled.
- Ask why CPA rose last week. Supply your target, reporting definitions and business context.
- Verify its answer against the ad platform, checking conversion lag and whether the evidence supports its conclusion.
- Once you can verify the analysis, enable write access for that account and select "All live changes." Review one adjustment, approve it if appropriate, then check the result.
Use your existing AI tool without building an agent yourself. The campaign management setup guide explains access and subscription requirements.
Try campaign management with controls you choose
Start with a campaign question you can verify, then use the results to decide what to delegate next. Keep live changes subject to review while you test the workflow, and monitor the outcome of every approved adjustment.
Connect an account to Supermetrics for Claude or Supermetrics for ChatGPT and ask: "Investigate why CPA rose last week. Check conversion lag and show the evidence before proposing changes."
Frequently asked questions
An agent can handle data gathering, investigation and campaign preparation, giving your team more time to judge the next step. Your team still sets goals and supplies context the data cannot reveal, such as upcoming promotions.
Supermetrics connects marketing data to Claude, ChatGPT, Gemini Enterprise and Microsoft Copilot. Campaign management works through supported AI integrations and the MCP server; check the setup documentation for capabilities.
Base the decision on the agent’s performance, rather than a fixed testing period. Before granting write access, check that it consistently retrieves the right data, follows your definitions and produces recommendations you can verify. Then test reviewed changes on one low-spend account. Workflows that make repeated changes across client accounts need more validation than a simple investigation.
AI agents can support multiple client accounts, provided you restrict each workflow to the client data and write access it needs. Give every live change a named approver. Select which accounts can receive changes, restrict client data visibility separately and agree who approves live changes for each client.
